Instant fuel consumption in TS
Hello all,
Back in the day when I was at MS1 I found an explanation here how to configure TS to show instant fuel consumption on one gear and it worked. It seems though that MS2 configuration is not as MS1 so I can no longer use the same method now.
I am looking for a way to do it, both instant and average fuel consumption. I am using MS2 3.4.0 firmware.
Re: Instant fuel consumption in TS
I can't help you out totally, but I like to use the instant fuel consumption gauge configured for gallons per hour. While driving, if I'm curious about MPG's, I take my instantaneous speed divided by the GPH readout from TS. What's nice about this is that it is not gear dependent.
1990 Nissan 240sx / SOHC KA-T / DIYPNP
What you need to do is create / Edit a custom.ini
Add an OutputChannel named userSpeedMph
put that custom.ini in the folder:
[YourTSProjectFolder]/projectCfg/
Then in TS select:
Data Logging --> Performance & Economy Fields
Set Vehicle Speed Source to: userSpeedMph
Code: Select all
[OutputChannels]
userSpeedMph = { an expression to derive speed based on RPM }, "MPH"
Then in TS select:
Finally got the time to play with the car again after the winter.
So it seems I have done something wrong as I got this error after editing the INI lately:
1 Errors:
Error: Variable 'RPM' used in expression, but not defined as OutputChannel or Setting Parameter in M2, Problem at:
[mainController.ini]:[Line:5242]: userSpeedMph = { (RPM*3.14*576.58)/4.22 }
Should I do something about "RPM" also? Any ideas?
Thanks.
PS: I think I found the solution. It seems that the variables there are case sensitive. I just had to write "rpm", small letters.
1 Errors:
Thanks.
Today I drove the car but without success as both gauges stay at 0.0. They are GaugeInstantLiterPer100Km and GaugeAvgLiterPer100Km.
I have set all vehicle specifications in TS, speed in KpH and fuel in Liters. I do not get the above error any more while loading the project.
Not sure what to do next.
Make a project Archive and send it to support <at> efianalytics.com with a reference to this thread.
We will take a look at it and see what's up.
I had some misunderstanding about the ini files. When I did it exactly as quoted above, it works now OK.LT401Vette wrote:What you need to do is create / Edit a custom.ini
put that custom.ini in the folder:Code: Select all
[OutputChannels] userSpeedMph = { an expression to derive speed based on RPM }, "MPH"
Then in TS select:
The calculation is correct only for one gear of course.
In TS3 the settings for userSpeedMPH have been added to the UI as normal inputs.
Also, TS3 has a UI based ini editor, so that should make life easier in the near future.
