Afr saftey shutdown?
Is there a setting for afr saftey to kill the motor if a set limit is reached for a givin period of time? Iv heard it mentioned in talks about safe tuning but havent found it in tunerstudio. Im using ms2 v3 extra3.4.0
Re: Afr saftey shutdown?
What happens 200 miles from home and the controller or sensor goes belly up?
Doesn't sound like a great idea to this old fart.................
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Pretty sure that feature is MS3 only.
That is an ms3 feature and is tunable. You can have it ignore map below and along with rpm below. So even if sensor takes a crap, afr shutdown will reset after a period time and back to normal till under boost again
Thanks for the info
That relieves all of my anxiety!nathaninwa wrote:That is an ms3 feature and is tunable. You can have it ignore map below and along with rpm below. So even if sensor takes a crap, afr shutdown will reset after a period time and back to normal till under boost again
