MS3 MS3x TS 2.6.19
1.In TS it shows MPH as vehicle is moving however when I go look at my logs with MLV dont see an option to view MPH using GPS. Which option do I select in the viewer to see GPS speed?
2.In TS designer mode e85 guage is set in properties as follows, select output channel has Controller set (default) and out channel (fuel_pct). I have tried another option with name "flex" but did not display any data on gauge. Flex fuel sensor is working as I have it with a digital gauge and shows accurate. What should the output channel properties be if wired to pin 5 flex input?
3.I am using Nitrous 1 low fan pin 24 and Nitrous 2 high fan pin 25. What should the channel properties be in TS to turn on an indicator so that I know fan is running? Looked at all available but did not see ones specific for those outputs.
Questions GPS speed, E85 and on/off Nitrous
Re: Questions GPS speed, E85 and on/off Nitrous
If GPS is on in TS, it should be getting logged as MPH in your data log. All the GPS channels should be in your logs: Longitude, Latitude, Heading, Accuracy, Altitude, GPS.SatelliteCount, etc..1.In TS it shows MPH as vehicle is moving however when I go look at my logs with MLV dont see an option to view MPH using GPS. Which option do I select in the viewer to see GPS speed?
The other 2 questions are MS3 specific and probably should be posted in the MS3 forum.
Thanks the MPH is working now, not sure what happened a few weeks ago when I was trying to get data.
