For convenience I am running TunerStudio 3 beta in Windows 7 Starter on a Toshiba NB250-107 Netbook to tune my MS installation.
When I open VE Analyze Live and click on the 'Advanced' tab, due to the screen size, not all of the function buttons are visible but those which are visible work correctly.
When I switch VE Analyze Live to full screen all the advanced function buttons are visible, including Lambda Delay, but most of them no longer function so the Lambda Delay table is inaccessible in either display mode.
The same problem occurs if I run the program in Windows 10 on my laptop but, because all the advanced function buttons are visible in standard screen mode, I can at least access the Lambda Delay table. If I change to full screen mode however the same problem occurs and only the 'Custom Filter' and 'AFR target' buttons work.
How can I access and tune my Lambda Delay table on my netbook please?
Can't access Lambda Delay Table in TS 3 beta
Re: Can't access Lambda Delay Table in TS 3 beta
I've added the images to clarify the problem.
Interesting... Nathan Hardy has been having this trouble too, but I guess this shows it isn't limited to him.
Showing which ones work and which ones don't should help to figure out what is different between the 2.
2.9.114 seems to have cured the problem.
Thanks for the swift reply and prompt action.
John
John
It was related to the pop to full screen, that is the part I was missing.
