CLT gauge in %?
CLT gauge in %?
Hello,
I've got MS1 2.2, running TS, not the 3 yet but the one just before that.
Why does my gauge read in % and not in degrees C? how do i change that?
i did a bit of search but nothing showed up
Cheers
Andy
Cheers
Andy
Re: CLT gauge in %?
That would be set either in your firmware ini or when the dash was created/edited in designer mode.
What firmware and what dash are you using?
Re: CLT gauge in %?
029y3********* sound about right? its MS1 2.2
that was from the properties under the file tab.
stock gauge cluster that came with TS.... worth trying others? (if thats what you mean by dash?)
Thanks!
Andy
Thanks!
Andy
Re: CLT gauge in %?
Just checked log info an it says this
MS1/extra format 029y3**********:ms1/extra Rev 029y4**********
Re: CLT gauge in %?
Ok, MS1 Extra.
That is generated from the ini, but if there was a percent in there, seems li like we would have noticed. I don't think much has changed with MS1 in 8 or 9 years.
If you go into Designer mode, you can change pretty most anything about the gauge, including the title and units text.
Which stock one, there are a number? The Default 8 Dial?stock gauge cluster that came with TS.... worth trying others? (if thats what you mean by dash?)
Re: CLT gauge in %?
Yeah ms1.LT401Vette wrote:Ok, MS1 Extra.
Stock 8 dail.
So what does that gauge read in? I've worked out I can change the text but I could change the text to F or *C but what is the gauge actually reading, *c or...? If that makes sense? It's using a GM Clt sensor.
Thanks for your help!
Andy
Re: CLT gauge in %?
Weather they are in C or F depends on what you are set to in Project Properties.
F is default.
Press CTRL+P, the look on the settings tab.
The ini with TS looks like it is showing them fine as C & F. I might need an export of your Car Project to see what is up.
F is default.
Re: CLT gauge in %?
LT401Vette wrote:Weather they are in C or F depends on what you are set to in Project Properties.
F is default.
Thanks bud, I'll take a look when I'm home tomorrow and see what's up
Re: CLT gauge in %?
so i looked as you said and it is setup as *C so i just adjusted the text on the dial and all seems well thank you!
