No controller found
justin_l_
No controller found
Post by justin_l_ »
I have been struggling through this whole megasquirt thing much more than I expected to. Latest, when I try to start a new project I get a message:
No controller found
Check your connections and be sure to have COM port drivers installed.
Consult your serial cable provider for the correct drivers.
I have had it connected in the past with the same laptop, cable and adapter, but now I can not get it to connect. I need help. The car is a 91 Miata with MSPNP that has a MS2 chip installed and is running the latest firmware.
I am not very computer savvy apparently because a lot of the stuff I am reading just sounds like jibrish so if you can help me it would be greatly appreciated!
slow_hemi6
Re: No controller found
Post by slow_hemi6 »
First point of call. Plug in your serial adaptor to your lap top. Go into device manager > hardware > ports and see if your device is there. Double click it and see if it says enabled and working correctly, is set to 115200 baud rate.
Cheers Luke
justin_l_
Post by justin_l_ »
It says it is working correctly and the baud rate is correct. I broke down and bought a new one tonight, installed it and it works now. Not sure why the old one wouldn't connect. Thank you for the timely response, I imagine I'll be back shortly with something else.
