MLV in TS, Corse read at 6500 & not 800 RPM how t0 change it
Re: MLV in TS, Corse read at 6500 & not 800 RPM how t0 chang
That would be in the folder:
[YourProjectFolder]/projectCfg/project.properties
You are way too deep.
It is in the parent folder of your project.
By default on Windows the TunerStudioProjects folder will be in your Documents folder...
So:
Documents\TunerStudioProjects\TunerStudioAppDebug.txt
So:
I am getting to Old.
The extension rar is not allowed.
Phil I will email it to you.
Gavin
LT401Vette wrote: Documents\TunerStudioProjects\TunerStudioAppDebug.txt
Gavin
I'm with you...I am getting to Old.
I got it, right file, but not .Phil I will email it to you.
For some reason the file you sent is from 2014.
Do you by chance work with your projects somewhere else these days, like in a dropbox folder?
If so, that is where TS would be writing the TunerStudioAppDebug.txt, to the parent folder of the last project opened.
Actually, looking in the file, the last time you ran on that file, you changed dirs and it looks like you have (or did have) a TunerStudioProjects folder inside your TunerStudioProjects Folder:
So it might be the other one.
Code: Select all
8/7/14 6:40:07 PM :Debug: Directory Changed:
Old:C:\Users\Gavin Lodewick\Documents\TunerStudioProjects\TunerStudioProjects
New:C:\Users\Gavin Lodewick\Documents\TunerStudioProjects
Hi Phil
Sent Ultra TunerStudioAppDebug.txt.
Gavin
Gavin
Phil this is what was discuss a few pages back.
Re: Tuning & Dyno Views TS 3 2.9.108
Postby LT401Vette » Tue Apr 05, 2016 12:40 pm
I don't have any bundled for the MS1 High Res Code yet.
The MS1 Extra ones should work fine, but will not be identified as good with the different signatures.
Load the attached.
Ultimately I want to get better ones worked out before the GA release.
MS1ExtraDefault_TuneView.zip
(294.76 KiB) Downloaded 11 times
Gavin
Load the attached.
Gavin
Gavin, I am not seeing any exceptions related to the tune views in your app debug.
Is it specific to the one project?
Try a different project, if the other project works, then if you could create a Project Backup and send it my way, it would be appreciated.
Hi PhilLT401Vette wrote:Gavin, I am not seeing any exceptions related to the tune views in your app debug.
Kick my ass, I had to right click on clear Dyno View screen and select Main Fuel ect.
sorry I gave you extra work.
Thanks Gavin
