I've just updated the cal on my MS1 extra with new CTS and IAT values and I've copied the .inc files to the TS inc folder. From what I can tell the temperature is reading as per the calibration using the jstim, ie. 5k = 78degC. However in TS the gauges stops increasing in value above 102 but the ADC continues to change so the hardware is registering the resistance of the pot and transmitting this correctly. Max ADC value that = 102 is ~120 for the CTS and ~20 for the IAT. I've tried both a digit displaying gauge and needle type, both have the same problem.
Any ideas what is causing this and how it can be resolved? I suspect it's something to do with the new inc files..
TIA.
Gauge Doesn't Match ADC
Re: Gauge Doesn't Match ADC
See the attached file. The second column goes to 255T at the same ADC value as the problem occurring.
No one?
That is the issue... The column that goes to 255 is the column TS uses for the lookup. It looks like EasyTherm was using a byte for that column and railed it out at 215°F. (255-40)The second column goes to 255T at the same ADC value as the problem occurring.
You need an inc file that to keep going through the rest of the sensors range.
Thanks for the response. Does the range extend beyond 255 normally? Would this be a limitation of easytherm? I can work out what temperatures should give what value of ADC, can I just modify the file by hand so that one column is ADC and the other is temperature in degF?
Yes there is a problem in that file..jammy86 wrote:Thanks for the response. Does the range extend beyond 255 normally? Would this be a limitation of easytherm?
when looking at the values in the inc file:
Code: Select all
DB 255T ; 114 214.78
DB 254T ; 115 214.08
So it should not stop at 255. The real value is listed all the way to the right. By adding 40 to that and rounding it to an integer, it should work.
Sorted. A thousand Internets to you good sir. Thank you for your help.
