TS 3 bug: Direct entry in cells in tables
This must be a bug, or at least it shouldn't be intended behaviour. When typing contents in one cell of a table, one would expect that a mouse click on e.g. a neighbouring cell would select that cell for editing. It does not, it just commits the contents you typed and leaves the cell you just edited selected. You have to click (mouse) twice to select the cell you intend to move to. TS 2 did not exhibit this behaviour, I think.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: TS 3 bug: Direct entry in cells in tables
It does the same here on 2.9.117
For the sake of completeness, observed in 2.9.117 here too, but I think it may have been like that since the first TS 3 beta.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Yes, that appears to be an unintentional side effect.
Still there in 2.9.118
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Not for me?subwoofer wrote:Still there in 2.9.118
VE, AFR target and spark tables work as they should, Crank Taper (and probably all the others that look the same) does not.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Ok, so new similar issue with Curve graphs?
Was there in 117 too, can't say when it began.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Seeing that that widget is brand new to 2.9, it is probably safe to say it has always worked this way.
also directly entering a negative number is impossible. if you highlight a cell and hit"-" then number it pulls up a subtract from dialog.
Interesting conflict... The minus button has always brought up the subtract dialog, but I guess there aren't many tables with a negative value.ashford wrote:also directly entering a negative number is impossible. if you highlight a cell and hit"-" then number it pulls up a subtract from dialog.
nope not many places, only thing i can think of is clt temp, and adaptive idle spark but older versions of ts allowed this on 2d graphsLT401Vette wrote:Interesting conflict... The minus button has always brought up the subtract dialog, but I guess there aren't many tables with a negative value.ashford wrote:also directly entering a negative number is impossible. if you highlight a cell and hit"-" then number it pulls up a subtract from dialog.
There is still an issue with 2.9.118
If you select a cell in 2D tables and start typing, the value change. Then you press tab to go to the next cell. The next cell is highlighted but the focus is stil on the previous one and if you start typing again, the text still appear in the previous cell...
This is really annoying.
Works in 2.9.120. Thank you!
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
