Im planning on putting my MS3x on a 1983 911 3.0L to drive twin plug coilpacks while keeping my webers and Im wondering if there is a way to change the VE Analyze Live/ Warmup Enrichment autolearn to use something other than coolant, since I dont have any
what I would ideally like is to use either EGT or cylinder head temp, but would accept the ability to use oil temp (I have almost 20 qts of oil in my car with my front mount oil cooler so its not the best indicator of temp on a cold engine)
VE Analyze Live/WUR without *coolant* temp?
Re: VE Analyze Live/WUR without *coolant* temp?
The VE Analyze min temp filter threshold can be adjusted in the advanced tab. Set it below what every the CLT gauge is reading and it won't filter.
If you're staying with carbs what will you use VE Analyze Live for?
