Can I please get some help about how to debug SD card logging issue - When TS connects to MS3 & I select the browse/import SD card files, all I got is a spinning circle that says "SD card card not in".
I created 2 indicators: sd_error & SD_Status on the dashboard, both showed 0.
This is the same SD card that used to work - I just downloaded the files off it from 2 years ago (unfortunately - the car had been down the last 2 years) so I assume the card is readable by MS3.
thanks!
SD Card Logging Help Please
Re: SD Card Logging Help Please
That "SD status" means the card is not physically in.
umm... the card is physically in and I can read it off my laptop.
Any suggestion of what to do next? Try another card?
Are you putting the SD card in the ecu or just the laptop?
Cobra replica with 383 Chevy, ITB's, MS3X and LS2 coil near plugs
The SD card is in the ECU (MS3 SD card slot). If I remove it & put into laptop, I can read the files. When I leave it in MS3, I got SD_status = SD_error = 0; which James said means MS3 doesn't see the card at all.cobratone wrote:Are you putting the SD card in the ecu or just the laptop?
