First of all, thanks Phil. The new tunerstudio is absolutely great. The new feature for selecting multiple cells and dragging the whole selection greatly drecreases tuning time and effort, not to say all the other features. The dyno tuning views are phenomenal, but im having some trouble editing them, Ill let you know shortly because there seems to be a small bug. Great great software.
I have a very small feature request for you, if its possible:
In the dyno tuning view, when I select a cell (or a group of cells) in the 2d table view, is it possible to reflect that selection in the 3d view as well?
If i edit the cells, I will get the yellow points in the 3d view, but I would like that when I navigate over the cells in the 2d fuel table view, I would also like to see that selection in the 3d view that lies underneath (in the standard view)
I dont know if im explaining myself well. If not, please let me know.
Thanks a lot!
small feature request... TS3
Re: small feature request... TS3
That is on the todo list. I would like the normal tables to work that way when you toggle back and forth 2D to 3D have the selection be consistent.In the dyno tuning view, when I select a cell (or a group of cells) in the 2d table view, is it possible to reflect that selection in the 3d view as well?
However, even though it would seem simple enough to accomplish, due to the underlying TS architecture that isn't straight forward. 2 separate widgets never talk directly to each other in TS, so there needs to be a new framework to handle that. For 3.0, I've pretty well froze scope so I can get a stable release out, there are several things I still wanted to turn on but aren't ready. Hopefully that will be in the 3.1 release.
Sounds great Phil... thanks for the quick responseLT401Vette wrote:That is on the todo list. I would like the normal tables to work that way when you toggle back and forth 2D to 3D have the selection be consistent.In the dyno tuning view, when I select a cell (or a group of cells) in the 2d table view, is it possible to reflect that selection in the 3d view as well?
I have another question regarding the dyno views...
I have found that the dyno views are really really useful, but im having trouble editing gauges inside a gauge cluster view.
Sometimes when I right click over the gauge cluster view, it will give me the menus for adding a new gauge or whatever, the same menu we get when editing the standard gauge cluster. But some other times, it gives me the other menu. I have not found how to make the gauge editing menu to appear, instead of the other menu... I took a few screenshots to let you see what im referring to...
In this one, I select the gauge cluster view and then right click, and this menu appears
But some other times, doing exactly the same, this menu appears (this is the one I need, so that I can edit the gauges inside)
am I doing something wrong?
I could not reproduce this, then I tried on the Mac Book... Seems to happen there
I'll have to look into this.
Ok, I just put up a new build 126 that should fix the popup menu.
Just tested it. Works perfectly. Thanks phil.LT401Vette wrote:Ok, I just put up a new build 126 that should fix the popup menu.
Sent from my Nexus 6 using Tapatalk
