Hello,
how can I display MAF/MAT-Correction in Tunerstudio ?
My custom.ini has the following entries but that don't work.
[OutputChannels]
MafMatCorr = { matCorrDelta }
[GaugeConfigurations]
gaugeCategory = "Sensor inputs2"
MafMatCorrGauge = MafMatCorr, "MAF MAT Correction", "%",-50,100,-50,100,-50,100,100,100
MS3 FW 1.4.1
Regards,
Jan
How to display MAF/MAT-Correction ?
Re: How to display MAF/MAT-Correction ?
Just to make sure I am clear, you are looking to create a new OutputChannel where the value is based on TS doing the lookup on matCorrDelta using mat against matCorrTemps?
Basically in the end have a Channel that provides the value of the green dot on the curve graph, correct?
correct, I expected something around 0.0.
I think I have just what you need.
Use TS 3 beta...
Use TS 3 beta...
Code: Select all
[OutputChannels]
MafMatCorr = { tableLookup(array.matCorrDelta, array.matCorrTemps, mat) }, "%";
thanks alot.
That only works in TS 3 and not in TS 2.6.14 ?
BTW: It would be nice to have MAF/MAT Correction in fuel calculation summary (in MAF mode, instead of air density correction)
Yes, the tableLookup() function was added after 2.6.x
You can do lookups on 2D tables too.
