accuracy of fuel trim autotune
How accurate is this or is it suffering from the same problems as regular autotune with regards to exhaust gas delay ?
Re: accuracy of fuel trim autotune
It uses the same delays as normal auto tune.
If you are having issues do to the delay settings, you either have a very odd set up, or more likely have a problem somewhere else.
They argument 'have a problem somewhere else' is usually used here when the developpers don't have an answer. It's plain wrong in a lot of cases.LT401Vette wrote:It uses the same delays as normal auto tune.
Could be, but thus far you have not provided any information or details about your issue. So unfortunately I have to fall back to past experience in supporting thousands of users for years.
Your case could be different, I run into new scenarios commonly. But again no details.
the msq is in the thread in MLV. What other specs do you need ?
Which thread? Give an exact link.Yves wrote:the msq is in the thread in MLV. What other specs do you need ?
I see you are using ITB mode, that is good to know. That is a minority usage.
What type of problem are you having?
Do you have a datalog where it was not behaving as desired?
I have not used autotune since I first went over to ITB mode. Like I said, I usually use MLV to dial in the fuel table. However, in all of the times I have used autotune in an effort to get close, it always gave results that were far from optimal.LT401Vette wrote:I see you are using ITB mode, that is good to know. That is a minority usage.
http://www.msextra.com/forums/viewtopic ... 00&t=63291jsmcortina wrote:Which thread? Give an exact link.Yves wrote:the msq is in the thread in MLV. What other specs do you need ?
So long as "Load" is being used as the load axis on the table, it shouldn't matter what fuel algorithm you use.
I agree.
