Got a question for anyone who uses the Megasquirt 2 Autotune Live function in the tuner studio software.
Shouldn't the tuning dart about the whole table, because it appears on this car that it doesn't and it is stuck in only the first top row going from left to right.
Also, is there any default maps that can be used for Mk1 1.6l 1997 Manual with no turbo as this car needs to be used tomorrow and we haven't got enough time to take out the megasquirt and refit the original ECU.
Autotune Live
Re: Autotune Live
What algorithm are you using?
It sounds like what ever is assigned to your load axis isn't reading.
By default, load is MAP. Make sure you m MAP gauge is reading, then post an msq.
