Hallo..
when i open my project i get this warning
1 Warnings:
Warning: Unknown 5th position attribute: =, known field Attribute: displayInHex, Problem at:
[mainController.ini]:[Line:3116]: field = "Soft limit Retard to", launch_sft_deg, {launch_opt_on } field = "Launch retard above", launch_sft_lim, {launch_opt_on >0}
I cant understand what it is ??
My car also go op and down whitout troudle.
suddently it begin whit that.
i have a log here and my msq.
It is a diypnp 3.3.1 and the newest tunerstudio.
has working for some yers now.
Regards Martin .Sorry for english
warning
Re: warning
That is an warning of a minor ini error for firmware developers. It will not effect you.
By Default TunerStudio does not show these warnings, but you may have turned on the menu item:
Options --> Advanced --> Report INI Warnings
If you un-check that again, it will not give you the warning.
Re: warning
Perfekt..Thank you so mutch.
I must move my other q to another topic .
