Feature Request: Quick Change of Coms method
jammy86
Post by jammy86 »
Hello,
I'm switching between bluetooth and Serial when communicating my MS. Serial is best when I need the connection to establish quickly between powercycles. It would be ace if there was a button or something that allowed you to set up a wired and wireless setup and switch between the two quickly without going through the communication menu.
grom_e30
Re: Feature Request: Quick Change of Coms method
Post by grom_e30 »
a hack way of doing it would be to have 2 different projects one set up for cable and one set for b/t just load the one you need at the time
jammy86
Post by jammy86 »
Yes, I can see that easily going wrong though and a sadface being produced :lol:
LT401Vette
Post by LT401Vette »
It does sound handy...
The 2 projects shouldn't lead to a sad face... You may get a difference report if you were changing on the other, but otherwise...
Still it would be handy to have a quick switch or secondary connection defined.
