TS Beta 3.0.06 not triggering logs.
Rick Finsta
Post by Rick Finsta »
TS Beta 3.0.06 MS2 Extra 3.4.0 over bluetooth won't trigger logs. I have it set up to start when RPM >70 and end when RPM <50 since my car cranks at around 110-130RPM. TS 3.0.05 is triggering correctly. I end up with 2.XXkb logs with no information in them, and usually only one per instance (that is, I get one blank log, and if I exit and re-enter TS Beta it will give me another log after a power cycle and reconnection to the ECU).
Let me know if you need anything else.
Rick Finsta
Re: TS Beta 3.0.06 not triggering logs.
Phil, did you ever find anything with this? I stopped using the Beta but now I had it happen in 3.4.0 release 20150710
LT401Vette
Post by LT401Vette »
Hmm, no I am not reproducing this.
Can you create a project back up and send it?
Rick Finsta
With apologies, you'll have to walk me through that. I think 3.0.05 and 3.0.06 share projects on my tablet so my project is most recently run through the 3.0.05 release. I actually did have this happen with 3.0.05 the other day, but it has only happened the once. Logs are garbage and no more than 2.8K in size.
FWIW there are reports of 3.0.05 doing this with SD logging on MS3 without any other changes so there may be something happening that is garbling settings? Some guys were talking to James on facebook about it yesterday and I thought it really odd that we were seeing the same behavior given the completely different firmware architecture behind how the external vs internal logging is handled.
Let me know exactly what you need me to do and I will do so post haste.
LT401Vette
3. anything won't matter here. They have no changes related to logging. So it happens with 3.0.06, most likely the same with 3.0.05
SD logging is quite unrelated again. All triggering is don't in the firmware for that.
To make a Project backup, on the main menu:
File --> Vehicle Projects --> Create Project Backup
Uncheck "Include Log File".
