I'm wiring up ignition control on a 6 cylinder motorcycle that was previously fuel only with a microsquirt. I'm using a diyautotune quadspark ignition module to control the 3 wasted spark coils.
My question is, I know I have to wire a resistor from tps 5volt reference to the WLED wire for the spk c output but is there a setting in tunerstudio that I need to change so that the microsquirt knows that is has a 3rd spark output? Or does the microsquirt magically know what it needs to do?
I have looked all over TS and the manuals and have not found anything how to program the MS to know that is has 3 coils to control....
Thanks in advance,
Dustin
Sent from my SCH-I545 using Tapatalk
Spark "C"
Re: Spark
It knows because you have put 6cyl in the Engine and Sequential settings and you select Wasted Spark in Ignition Options/Wheel decoder.
Re: Spark "C"
And again thanks for your response, slow_hemi6. Your answer is what I assumed was the case.slow_hemi6 wrote:It knows because you have put 6cyl in the Engine and Sequential settings and you select Wasted Spark in Ignition Options/Wheel decoder.
I sleep better when I know rather than when I assume....
Thanks again
