IOx issues (MS3 pre-1.5 alpha 4 released)
Having an issue with the Generic PWM dialog when working with Jean's TinyIOx board. If you try to switch "Table or Curve" into Curve mode, the dialog grays out the table and does not display the curve graph or the editing rows.
It works correctly using the current stable firmware, 1.4.1
Is this a firmware issue or a problem with Jean's current ini?
MS3-Pro
Using latest TinyIOx firmware: 0.2.0
MS3-Pro
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
Re: MS3 pre-1.5 alpha 4 released
There was a problem with the ini so if you did not download it recently, you need to use this one: http://www.jbperf.com/io_extender/firmw ... inyIOx.ini. And you need to use the latest TunerStudio version.
That is the ini file I'm using. Did a diff compare just to be sure.racingmini_mtl wrote:There was a problem with the ini so if you did not download it recently, you need to use this one: http://www.jbperf.com/io_extender/firmw ... inyIOx.ini. And you need to use the latest TunerStudio version.
Since this has nothing to do with the MS3 pre-1.5 alpha 4, you should create another thread in the TunerStudio section of the forum (since this seems to be a TS related issue). And in there, post a backup of your project.
Re: IOx issues (MS3 pre-1.5 alpha 4 released)
What version of TS are you using?
(Please don't say the latest)
Can you post / send a Project backup?
I am using TS v 3.0.05
Here is a backup of the project. It is not from a running car, I am just setting everything up.
The problem does not happen if I load the current stable firmware and try it it (v 1.4.1) so I'm not sure that it is a TS issue.
Since you can only upload a 715kb file I deleted everything I think is not needed in the zip. If I deleted something important, let me know.
It looks like you have it set to use a Curve Editor instead of the Table, so the table should be disabled.
You also have it set to use "RC Servo Extended (0.5-2.5ms, 50Hz)" in Base I/O settings.
However, in the ini there is no valid Curve option for timer_source2 = 3, so I don't think this is a valid setup.
Jean?
Jean?
Yep, that was a mistake on my part. I had forgotten to change (and test) that when I added the new option (timer_source2 = 3). I have updated the ini file on my site so if you reload it from the same link as above, you will get the corrected one.
By the way, timer_source2 == 2 was supposed to be timer_source >= 2 since options 2 and 3 need the same table.
Works after updating with Jean's fix.
Thanks everyone.
Thanks everyone.
