Update won't complete, says TS is running
anesthes
Post by anesthes »
Any known trick on windows10, Tunerstudio ultra 3.0.06 getting the update to continue? It thinks TS is running (but it is not).
Is there a lock file somewhere I can delete?
-- Joe
Spongo
Re: Update won't complete, says TS is running
Post by Spongo »
I am getting the same is there a potential issue?
Range Rover 630R with Sequential MS3 using 60-2 trigger wheel and MSD CAM sensor.
Tech Edge 2J2 O2 sensor
Brian H EFI
Post by Brian H EFI »
Have you checked the Task Manager for any instances of TS running? What I would recommend is power cycle the laptop then try downloading the update or you could do the power cycle then download and run the installer for TS Beta v3.0.08.
http://www.efianalytics.com/TunerStudio/beta/
Spongo
Post by Spongo »
So if I download the new version and install my tune files etc wont be corrupted and will still work?
Brian H EFI
When the Installer is run it does not edit or modify anything in the TunerStudioProjects folder so they will not be affected.
slow_hemi6
Post by slow_hemi6 »
I have had mine hang on that screen before. It usually just finishes the update if I just do a restart on the computer.
