Update Failed
Update Failed
Hi
I said yes to TS update.It come up with the following error message.
"Invalid or corrupt jarfile TunerStudioMS.jar"
I can't open TS.
I then thought i would download TS again.
I got this error message.
" The setup files are corrupted. Please obtain a new copy of the program."
My laptop is running window 10.
Cheers
I can't open TS.
Cheers
Re: Update Failed
Downloading the installer is the right move.
But it sounds like the installer download failed too..
Internet troubles?
I would try downloading the installer again, perhaps from the other location...
It is in 2 places:
http://www.tunerstudio.com/index.php/downloads
and
http://www.efianalytics.com/TunerStudio/download/
Internet troubles?
It is in 2 places:
and
Re: Update Failed
Got same issue on auto-update today, didn't have time then to do anything, grabbed spare laptop and turned off wifi first...
CRC checking before installing the updates?
Re: Update Failed
Also horked when updating second machine, 50MBPS wired connection.
Sumtingwong with auto update, manual reinstall from website fixed, but something is broken.
Re: Update Failed
Hi
I have the same issue.
I have downloaded the auto-update yesterday and now I can't open Tunerstudio. I have W10, too.
I have no idea what I have to do.
Regards.
Regards.
Re: Update Failed
I just tried again on same machine (another OS install) and it worked, so YMMV.
(I had it work and choke on Win10 and Linux, same 2 machines, multiple OS installs)
Probably best to just manually DL the installer or Linux archive for now and turn off updates until resolved.
Re: Update Failed
I have just reinstalled Tunerstudio MS from http://www.efianalytics.com/TunerStudio/download/ ( I couldn't do it from from
http://www.tunerstudio.com/index.php/downloads) and now it seems work fine.
Re: Update Failed
Mine is dead too after auto update.
I'm going to manually down load.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Re: Update Failed
Now I'm starting to get curious... Going from 2.6.x to 3.0.x is a big update, easier for something to get interrupted.
The 3.0.x to 3.0.x updates are relatively small and hundreds of people have updated no problem, but the failure rate does seem to be higher than usual. It seems there is some factor here.
Re: Update Failed
Mine were 3.0.5 to 3.0.9
Re: Update Failed
I'm glad I put off updating until I was at a stable tune. I got the same error on a Win7 64 intel i7 laptop -"Invalid or corrupt jarfile TunerStudioMS.jar" after answering the update offer upon TunerStudio start.
Tried updating my Java & some re-starts after, no good.
Scary, as both my cars are on MS3 and are never fully tuned....
Manual update from the website worked fine, although I always worry about losing my registration info!
It seems like the last update not to long ago went through just fine via the in-program prompt for me.
Lotus Esprit w/MS3x, COP, Sequential, GM TB&IAC. Hall sensor on 36-2 crank,1 pin VR cam. MapDaddy, AEM X WBO2, Clock&Knock boards.
Subaru WRX hybrid w/MS3PNPPro SW0205, STi cams, VF39 turbo, 830cc injectors, VW boost solenoid.
MS3 1.5.1
TS v3.0.28
MS3 1.5.1
TS v3.0.28
Re: Update Failed
Same problem updating from 3.0.9 to 3.0.10 on Linux Mint.
Downloaded installer and everything was fine.
Re: Update Failed
Update to 3.10,04 has gone smoothly in all cases, win10 and Linux.
Re: Update Failed
Downloaded installer from http://www.efianalytics.com/TunerStudio/download/.
Worked okay. I can open TS now.
Have not tired connecting up to ecu yet.
Where will i find whats new with the update?
Re: Update Failed
http://www.tunerstudio.com/index.php/do ... ngelogmenupanther wrote: Where will i find whats new with the update?
Re: Update Failed
Just wanted to chime in I had the same issue using the auto update. Using a download from EFI works fine.
Re: Update Failed
Same here last night. I have two Acer netbooks that have worked fine previously. Both came up with same broken jar error. can you substitute a flask?
1972 Triumph TR6
Dual Extrudabody ITBs
Megasquirt 2 extra/V3
Re: Update Failed
I still need to do this update although I don't think thee is much benefit for my use (MSPNP v3.57 + TS 3.0.14). Hopefully, it fixes some of the issues with Gauges & Shadow dash as I can't seem to create the same displays as everyone else. Maybe its a short between seat and keyboard.
jim
jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Re: Update Failed
It all seems to work fine if you just download the new version from his website and install.
I have not had any more update issues since I posted, probably 3-4 updates since.
The whole networking thing looks bulletproof these days but can still suffer from glitches...
Yahoo! doesn't even need to be involved.
I was having network/data corruption issues on a recent "insider' build of Win10, downloads and updates always got corrupted, wired or wireless--- only on one machine too, my old X300 worked fine on same build.
Reverted it back to previous build, then it updated fine and working well on latest builds.
Re: Update Failed
The latest release 3.0.15 performs checksums and partial file retries. So even if you are on a crappy network, updates from 3.0.15 forward should be rare to fail.
