Is it possible to put gauges behind the dashboard background, or maybe put just image on top of a bar gauge?
I would like to use an image with some transparant cutouts for gauges and put some bar gauges behind it so the gauge is only partly visible.
Can I put a gauge behind the dashboard background?
Re: Can I put a gauge behind the dashboard background?
Can't put something behind the background, but what you can do:
Add an indicator and set an off image
I tried that already but once an indicator has an image (on or off) the order of that indicator is always in the back.
I can place a normal indicator on top of a gauge, great. However, once I give it an image, the indicator goes behind the gauge
AIs there a way around this?
