I am slowly but surely moving our enduro cars (miatas) and some customer cars to MS products.
I have a MS1 extra 9495 PNP that I use the bluetooth module to tune, often in pit lane, and/or to run shadowdash. Works great.
I put another bluetooth setup on a MS2 PNP for 99-00 miata, and I find I have to use an external power source, making the pit lane tuning or Shadowdash use not too convenient.
I can wire the car with a 12-5v converter, but I would rather it work like the MS1.
Is this correct? Is there a software output solution or a hardware solution? I don't know what pin on the serial connector the module would need for 5v internal power if I need to alter the hardware.
Thanks in advance for any help!
Kyle
Sector Purple Racing.
Bluetooth not powered from ECM?
Re: Bluetooth not powered from ECM?
If it's a DIYpnp there's a jumper you can solder in next to the serial port. If you want (and I recommend it due to blowing one of my serial ports on a serial card) you can put in a pin header and use a jumper to be able to remove power from the serial port when you are using something other than a BT adapter.
Tha Daily: 2005 Chevy Blazer
Yes, there is a jumper in it to put 5v on Pin9... I'm not sure this is your PNP, but think it is:
http://www.megasquirtpnp.com/docs/mspnp ... nstall.php
Thanks!
I will get it back out of the car and check it out.
Much appreciated,
Kyle
SPR
Much appreciated,
Kyle
SPR
