DIY-PNP MS2 Old Firmware issue
Vince-R
Post by Vince-R »
The ECU is a DIY PNP MS2 - built & installed during the summer of 2010 - the current tune is good & working in a 1992 1.6 Miata.
The car was off the road for a long period, resulting in no connection between that of Tunerstudio & the ECU for around 4.5 years. The originating Laptop containing Tunerstudio & various tunes is dead, so I recently reinstalled Tunerstudio on a new Laptop, including a driver for the USB - RS-232, but hit an issue as I do not know which ini file to use when requested.
To reiterate, I know where the ini files are situated, but need to know which one to go with.....I'm sure it's something simple, but I really don't want to screw the only remaining (not backed up) tune that currently resides on the ECU. I need to get a connection before I can upgrade, but I don't see on option in way of older firmware versions that allows for this & all I've discovered so far (through 2-day extensive searches) is that the firmware on my ECU is obsolete & may even have been associated with MegaTune, also obsolete.
Assistance with this issue would be greatly received.
Re: DIY-PNP MS2 Old Firmware issue
Post by LT401Vette »
If you can get internet access to your laptop, it will find that ini..
If not, here it is.
Vince-R
Post by Vince-R »
Thanks Phil, your assistance is very much appreciated bud.
Vince.
