does this function not work with an MS2?
reason i ask this suppose you have you ATV, motorbike or jetski setup with an MS2 type ecu
you could use a rasberry in a pluggable unit to datalog if you could set it to start at say above 10 rpm and stop below 10 rpm
you unplug the rasberry , take it in you home where you make changes on a normal screen
then plug it back in
tunerstudio will give a difference report and you select tunerstudio version
don,t know how well you can do selection with a 3 inch screen on your rasberry in a plug-able case
but for small or preferably invisible setup,s this would be a great addition
maybe there could be support for some buttons to bring out the gpio connector
Tunerstudio triggered logging
