Hi Phil..
Got a weird one here for you...
Everything was working A1 on FTDI D2xx setup before.
I had to recently switch back to RS232 comms for a very old ECU.
Now when I try and switch back to FTDID2xx comms, TS bricks... solid..
Have to go into Task manager and shut down the JAVA platform for it to close..
Any Suggestions?
PS attached App Debug in RAR if it helps?...
Regards
Gordon.
TS 3.0.10 (TS Ultra Upgrade) - Hanging on switch to FTDI
Re: TS 3.0.10 (TS Ultra Upgrade) - Hanging on switch to FTDI
In the app debug file it looks to be hanging when trying to load the native library. It looks like you are running in a proper jre, so I am not sure why that would be.
Unrelated, It looks like you have a dash loaded with a lot of invalid limits.
Hi Phil.
Thanks for the response.
Update.. after a couple of reboots (WIN10 Pro BTW).. It all seems to be working again.
as for the dash issues... Running default dash MS1 in that case.
But all seems fine again...
Thanks.
Thanks.
