Hello, my English is very bad because I am Spanish.
Use Linux Mint 17.3
I have problems with Fuel Requirement Calculation
TunerStudio 3.0.10
Linux MInt
values:
Engine: 1800cc
Number: 4
Nozzle: 550cc
AirFuel: 14.7
Result 5.5 = 2,7ms
Windows
the values
Engine: 1800cc
Number: 4
Nozzle: 550cc
AirFuel: 14.7
Result 5.5 = 5.5ms
Why?
Calculate Required Fuel Linux Mint
Re: Calculate Required Fuel Linux Mint
I can't see under your dialog, but check to see if one is set to Alternating, the other to Simultaneous.
The required fuel dialog is coming up with 5.5 in both cases, but 5.5 will only be used if the injector is to be opened once every 120 degrees. If the injector is to be opened more times, reqFuel will be divided by the number of injector openings every 120 degrees.
