TS 3. 0. 10. 08 Corrupts MSQ MsI Extra Hr 11c2
Hi I have TS Ultra, and updated to 3.0.10.08 this update corrupts My MSQ When I make changes.
Running Ms I Extra Hr 11c2. I will put my old MSQ up.
Re: TS 3. 0. 10. 08 Corrupts MSQ MsI Extra Hr 11c2
What gets corrupted?
It think this line broke MS1....
- 2016-10-13 - Read only portion of page needed instead of full page on dialog open.
http://www.tunerstudio.com/index.php/do ... ngelogmenu
I'm glad you brought this to my attention before it got promoted to stable.
This might be digging up an older thread (by a couple weeks), but I experienced the exact same thing, although with plain-Jane B&G fuel code, and Hi-Res 10C. I thought I blew up my processor (again) so I ordered a DIYautotune assembled unit to eliminate variables, haha.
1984 Volvo 244
MS2 v3.57
B6304S swap w/AW30-40e transmission.
Transmission controller made from a BASIC stamp & arcade joystick shifter
MS2 v3.57
Yes it unfortunately effected all MS1 protocol ECU's.Broke4speed wrote:This might be digging up an older thread (by a couple weeks), but I experienced the exact same thing, although with plain-Jane B&G fuel code, and Hi-Res 10C. I thought I blew up my processor (again) so I ordered a DIYautotune assembled unit to eliminate variables, haha.
I have tried to make contact with the box since then, and the firmware uploader can't find it. I can connect to it with tunerstudio, but nothing reads properly. Is there a last-ditch way to upload the firmware? I've tried going back to the B&G fuel code, using the bootloader, not using the bootloader, but it just keeps erroring when I try. I'm not stressed, because I have a second MS1 now, but it would be cool to have two .
1984 Volvo 244
MS2 v3.57
MS2 v3.57
You shouldn't need to reload the firmware. All TS corrupted was tun data.
You should be able to load an old msq and be good.
If you do re-load the firmware; The boot jumper should work fine. You can not use TunerStudio's firmware loader as it doesn't support MS1.
Are you using B&G MS1 firmware, not Extra?
Ah ok, I'll try that.
I'm setting the car up on MSNS-extra (non HR for now), but flashed back to B&G to see if the problem was firmware related. I may be grappling with a separate issue too it seems, since my firmware comes up as '15' in project properties. I'll probably put this box aside for now, since I don't need it currently, and worry about it later.
1984 Volvo 244
MS2 v3.57
MS2 v3.57
