TS 3.0.12 Update Problem
Update detected, downloads, installs. Version still at 3.0.10.
Repeat...same, over & over.
Download full install, run, now at 3.0.12.
Tried on 2 different computers, same result.
Re: TS 3.0.12 Update Problem
That's good to know as I was going to do same this weekend. Think I'll wait until they get the new update sorted now.
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Same thing happened to me. Detected, downloaded, installed, still 3.0.10.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Worked for me.
Updated fine. Now on 3.0.12..
Best regards
Best regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Updated to 3.0.12 now. I had to download it separately and install it fresh.
Personal Vehicle:
Personal Vehicle:
That's the only way it worked for me.CRSTune wrote:Updated to 3.0.12 now. I had to download it separately and install it fresh.
Blown88GT - What edition TS are you using? (MS or MS Ultra). I checked and all the updates look to be correct.
There is error checking and retry logic in the auto update logic in 3.0.10.08 and up. However, that won't work unless you are already on 3.0.10.08 or up. This is the 1st stable release with the error handling.
With this error handling if it fails to download a file, it will not update the file and brick your TS install like in the past. It will retry file downloads 3 times before giving up.
TS MS updated fine from 3.0.10.08
TS-MS registered on 3 & TS-MS Lite on 2, no UltrasLT401Vette wrote:Blown88GT - What edition TS are you using? (MS or MS Ultra). I checked and all the updates look to be correct.
3.0.10 on all
No failures on downloading file update.
TS Install not bricked.
It's probably tried more than 3 times.
On 1 machine with Lite still at 3.0.10
I now select "Check for Update", then "Complete Update" or "Complete Later".
On reload, it's still at 3.0.10.
Uninstalled 3.0.10, reinstalled 3.0.10, same result.
Also not updating.
Auto update from 3.0.10 (registered version) to 3.0.12 seems to work but version stays on 3.0.10.
3 attempts
3 attempts
http://web.aanet.com.au/arran
Same issue not updating.
Linux machine, TS 3.0.10 registered version. Auto update appears to download and install, but when TS restarts its still 3.0.10.
Downloaded and replaced files to get to version 3.0.12
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
Me too......jsmcortina wrote:Worked for me.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Same thing here. Stayed at .10. It seems that the update process happens must faster than I remember. Only takes about a couple of seconds. Tried it a couple of times and same result.
All I can think of is that the download verification is failing, perhaps falsely?
I'm not sure why it would for some and not for most though..
Perhaps a looks at a TunerStudioAppDebug.txt
Here is a debug log from my Windows 10 machine while trying to do the automatic update. Didn't see anything too interesting though. I have not manually updated the machine in case you need any other tests.LT401Vette wrote:All I can think of is that the download verification is failing, perhaps falsely?
FWIW...... I just went out to my shop and updated my in-car computer without issue.....
Kind of strange, for certain!
jsiedlicki , it looks like your TS is never closing all the way.
I don't see an update in that log though.
Just to add, I tried updating a few days ago after reading this thread, and it's still .10 on my PC.
I do not get a prompt at start up like I have in the past, if that makes a difference. I do have check for updates on.
Tha Daily: 2005 Chevy Blazer
I have an update problem, too, but it seems to be different. The update fails with "Internal error: ./config.zip.temp.partial (Permission denied)".
This is on a Macbook pro running sierra.
