Unable to modify VE or ignition table
Chiburbian
Post by Chiburbian »
Here is the problem:
(TS MS Ultra - 3.0.12.02)
I am able to modify values on me VE table when not connected to the megasquirt. I can modify the table, close the window, and they stay intact.
When I connect the laptop to a running megasquirt I am unable to burn changes except the very first time that I connect. This applies to any table that isn't 3d. If I make the table 3d it DOES change/burn.
Here is video:
LT401Vette
Re: Unable to modify VE or ignition table
Post by LT401Vette »
Yes, this is an issue discovered earlier today.
It occurs after a difference report is received. All tables to not actually update.
I am putting together a patch release right now. It will be up within the hour..
LT401Vette
3.0.14 is released with a fix for this.
Chiburbian
Thank you!
Blown88GT
Post by Blown88GT »
If not connected, do you have to hit "Burn" for it to save?
I think I've seen it work one way or the other in different versions.
Didn't pay much attention until I read this thread.
Yves
Post by Yves »
I have the following issue after the latest update : I cannot change anything in the VE table, ignition table, trim tables,....Only when doing it offline, it is accepted by the ecu...
LT401Vette
Yves wrote:I have the following issue after the latest update : I cannot change anything in the VE table, ignition table, trim tables,....Only when doing it offline, it is accepted by the ecu...
Please read above your post...
I'm guessing when you said "Latest Update" you are not on 3.0.14.
Yves
Post by Yves »
yes I am. VE and ignition problem cleared up with that update but not the fuel trim for instance. Haven't tried the rest.
LT401Vette
Yves wrote:yes I am. VE and ignition problem cleared up with that update but not the fuel trim for instance. Haven't tried the rest.
I will need more info, I can not seem to reproduce this on 3.0.14. Fuel trim seems to be working fine.
Yves
Post by Yves »
what info ?
LT401Vette
A specific scenario to reproduce this in 3.0.14
Yves
Post by Yves »
running engine, didn't want to accept changes to trim table
LT401Vette
Try before you post it...
Yves
Post by Yves »
Are you bullshitting me man ? Maybe you should think first before you accuse :evil:
LT401Vette
I give up.....
