Indicators for inputs...
Hey,
Is there a way to see an enabled input using an indicator ?
I would like to see when MS see the tableswitch input or the clutch switch....
97 1.8T DIYPNP Seq Inj
http://megamiata.blogspot.co.il/
Re: Indicators for inputs...
If the firmware reports the pin state. What firmware?
Running 341 on DIYPNP
They are described in the TunerStudio Reference Manual.
Any news about the next fw with the ALED for EBC fixed ?
Not sure what you mean. Please start a new topic or bump an existing one. (i.e. don't post in this one.)elior77 wrote:Any news about the next fw with the ALED for EBC fixed ?
I read the manual, my clutch switch in connected to FLEX, and the manual says it is on PORTE0.jsmcortina wrote:They are described in the TunerStudio Reference Manual.
When I press or de press the clutch I don't see the indicator configured with PORTE0 comes on and off accordingly.
Where did you read that? (EDIT: I see where.) It's not PE0. Try PE2.
I do not see PE2 PORTE2...
Let me try again. I had MS3 in my head.
MS2 doesn't use PE2 for Flex. The typical input on an MS2 card is PA0/JS11.
I run diypnp, my clutch input in FLEX.
