upgraded to MS ultra now nothing works
hello,
updated from the free version to the latest ultra version and now when I connect to the ecu I cannot do anything (edit any ecu settings), and also when I click on the file window, nothing happens
Re: upgraded to MS ultra now nothing works
also I have tried uninstalling/reinstalling tunerstudio (after downloading it from the website) and still no dice
running windows 10
running windows 10
It looks like you may have inadvertently turned on "Dashboard only mode"
Uncheck the menu:
Options --> Performance --> Dash Only Mode
Uncheck the menu:
that did it!
not sure how that got turned on...
thanks
thanks
Is it just me or the dash only mode doesn't exist anymore ? (I have TunerStudio MS Ultra v3.1.03)
Simon Clavelle
MS3 Pro Evo / 2007 Ford Ranger 4x4 5.0L GT40P EFI
It does not.. It became pointless as it did not save any measurable time after other optimizations had been put in place. Meanwhile, it was quite common for people to turn it on and get confused.simonclavelle wrote:Is it just me or the dash only mode doesn't exist anymore ? (I have TunerStudio MS Ultra v3.1.03)
Ooh ok, I see. Thanks for your answer !LT401Vette wrote:It does not.. It became pointless as it did not save any measurable time after other optimizations had been put in place. Meanwhile, it was quite common for people to turn it on and get confused.simonclavelle wrote:Is it just me or the dash only mode doesn't exist anymore ? (I have TunerStudio MS Ultra v3.1.03)
Simon Clavelle
It is not gone just hidden - at least according to the change log. I have added this code to my PI and it is not adding the menu.
http://www.tunerstudio.com/index.php?op ... &Itemid=61
2020-08-13 - Released 3.1.02.05 as beta installer and auto-update
- Added TeamViewer Quick Support download for OS X
- Removed Verbiage on Non-Windows Detect dialog to upgrade for wireless support
- Remove Dash Only menu unless showDashOnlyMenu=true is found in the TunerStudio.properties file
I have opened a ticket with TS about the Dash Only Mode not working after adding the code. They confirmed the issue and are reaching out to the dev.
