Detection problems (MS2/Extra)
jrods2
Post by jrods2 »
Subject: Re:connection issues
I got my controller the other day and have just now started to get it to connect. Maybe you can help? I get a message saying " ECU configuration required, please provide a valid config file".
I do not a msq because I can't connect and there are none on my system.
While using the detect to connect I notice that it starts with 115200 baud then goes to 9600. I have also used port check and it opens com3 (is the port I've always used, have also tried other ports with the same results) it opens com 3 at 115200 and says no connection and goes to 9600 and says no connection, 1 valid port found" I have gone into device mngr to check the setting are correct 115200 com port 3, have also checked TS for com 3 and its correct. The last msg I got was as follows
" Your installation of tuner studio does not have a configuration to support the firmware found. Required Serial Signiture MS2Extra Rel 2.0.0 How ever this file is available on EFI Analytics servers. Would you like TunerStudio to download the file for you? I elected not to download because I know I have 3.4.2 firmware. I have uninstalled & reinstalled Tuner Syidio to no avail, BUT I do get the last msq project ford1.1 to keep coming up in recent projects. this project is I now believe is the source of my problems maybe. I'm using Jimstem for power only to get a connection. got any ideas on how to fix this?
additional info: can anybody analyze this? I have no idea what it means, it is a debug log that just saved itself on my computer
Starting on LAPTOP-IPFJP9SA
TunerStudio 3.0.14 started on Tue Nov 29 11:58:59 PST 2016
JRE 1.8.0_66, Windows 10 10.0, x86
java.library.path=./lib
TunerStudioMS.jar
Look:Metal, ClassName:'javax.swing.plaf.metal.MetalLookAndFeel'
Look:Nimbus, ClassName:'javax.swing.plaf.nimbus.NimbusLookAndFeel'
Look:CDE/Motif, ClassName:'com.sun.java.swing.plaf.motif.MotifLookAndFeel'
Look:Windows, ClassName:'com.sun.java.swing.plaf.windows.WindowsLookAndFeel'
Look:Windows Classic, ClassName:'com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel'
Look:Night Shade, ClassName:'de.muntjak.tinylookandfeel.TinyLookAndFeel'
Setting Look & Feel to:javax.swing.plaf.metal.MetalLookAndFeel
ScrollBar.width
11/29/16 11:58:59 AM :Debug: no update:defaultFont
11/29/16 11:59:01 AM :Info: Loading Language Content.
11/29/16 11:59:01 AM :Info: Initializing File Dialogs.
11/29/16 11:59:02 AM :Debug: Command Non-VolatileBytes for F resolved to: x46        F
11/29/16 11:59:02 AM :Debug: Command Non-VolatileBytes for I resolved to: x49        I
11/29/16 11:59:02 AM :Debug: Command Non-VolatileBytes for f resolved to: x66        f
11/29/16 11:59:02 AM :Info: Initializing Help.
11/29/16 11:59:02 AM :Info: Initializing Edition Features.
11/29/16 11:59:02 AM :Info: Initializing App Events.
11/29/16 11:59:02 AM :Debug: App Name:TunerStudio, appEdition:MS Lite!
11/29/16 11:59:02 AM :Debug: Dummy Function Factory Created.
11/29/16 11:59:02 AM :Info: Initializing User Interface
11/29/16 11:59:02 AM :Warning: Unable to set Main cluster for title:
arg found 0:C:\Users\jrods\AppData\Local\Temp\Temp2_ms2extra-release-3.4.2.zip\ms2extra-release-3.4.2\tune_files\default-3.4.2-megasquirt2.msq
11/29/16 11:59:04 AM :Info: Loading Font list.
11/29/16 11:59:04 AM :Debug: Time to retreive font name list: 251 ms.
11/29/16 11:59:04 AM :Info: Initializing UI Components.
11/29/16 11:59:04 AM :Info: Ready
11/29/16 11:59:20 AM :Debug: Directory Changed:
 Old:C:\Users\jrods\OneDrive\Documents
 New:C:\Users\jrods\Desktop
11/29/16 11:59:38 AM :Debug: Directory Changed:
 Old:C:\Users\jrods\Desktop
 New:C:\Users\jrods\Desktop\MS2
11/29/16 11:59:42 AM :Debug: File Changed:
 Old:null
 New:C:\Users\jrods\Desktop\MS2\ms2extra-release-3.4.2
11/29/16 11:59:42 AM :Debug: Directory Changed:
 Old:C:\Users\jrods\Desktop\MS2
11/29/16 11:59:46 AM :Debug: File Changed:
 Old:C:\Users\jrods\Desktop\MS2\ms2extra-release-3.4.2
 New:C:\Users\jrods\Desktop\MS2\ms2extra-release-3.4.2\Ford1.1
11/29/16 11:59:48 AM :Info: Opening Project ...
11/29/16 11:59:48 AM :Debug: Opening project: C:\Users\jrods\Desktop\MS2\ms2extra-release-3.4.2\Ford1.1
 Valid TunerStudio Project not found at:
z.a: Valid TunerStudio Project not found at:
 at V.a.b(Unknown Source)
 at V.a.a(Unknown Source)
 at ae.h.e(Unknown Source)
 at ae.h.a(Unknown Source)
 at ae.v.run(Unknown Source)
 at ae.h.c(Unknown Source)
 at b.run(Unknown Source)
 at TunerStudio.main(Unknown Source)
 null
java.lang.NullPointerException
11/29/16 12:00:07 PM :Info: closeApp Called
11/29/16 12:00:07 PM :Info: Finalizing Sensors
Saved user properties successfully
Sent: Tuesday, November 29, 2016 12:36 PM
slow_hemi6
Re: Detection problems (MS2/Extra)
Post by slow_hemi6 »
It is probably best if you follow the sequence set out in the Setting Up manual. From here http://www.msextra.com/doc/pdf/html/Meg ... .4-13.html
Cheers Luke
