Tunes too Old to Open ?HELP?
sentein
Post by sentein »
Okay found old MS1 tunes that i really really need. They are from 2008. I was opening them in an older version of TS for the last hour. I did the latest update due to being tired of seeing the pop up every time i loaded a tune. Now that i am up to date there is an error and none of these files will open. What happened? I have a registered version of TS so i want to use it. But if i cannot get these to open i will be forced to use Megatune which in the long run does me no good. How can i fix this?
slow_hemi6
Re: Tunes too Old to Open ?HELP?
Post by slow_hemi6 »
what does the error say?
sentein
Post by sentein »
Never mind, if i select an existing project example all of these tunes will load. TS cannot create a temp project, I believe this is due to the firmware in these files not having a config page originally. By config page i mean the page that you can change your F* to C* and speed density to Alpha N with wide band and MAP options as well. All the settings set when you create a new Project in TS.
Post by Matt Cramer »
Can you upload an example of these problem tunes?
sentein
Post by sentein »
Sorry for the link problem
Post by jsmcortina »
That link doesn't do anything. Please use "Upload attachment"
LT401Vette
Post by LT401Vette »
sentein wrote:Never mind, if i select an existing project example all of these tunes will load. TS cannot create a temp project, I believe this is due to the firmware in these files not having a config page originally. By config page i mean the page that you can change your F* to C* and speed density to Alpha N with wide band and MAP options as well. All the settings set when you create a new Project in TS.
It sounds like because you hadn't opened a Project yet, TS was trying to create the temp project somewhere that it wasn't allowed when you double clicked the msq.
sentein
Post by sentein »
Here is another one
LT401Vette
It does look like it is erroring out when loading old MegaTune msq's without a project open.
LT401Vette
It is due to the No O2 sensor being selected by default in the old MS1 Extra. The ini defines this as an error condition to abort:
Code: Select all
#elif ZEITRONIX_NON_LINEAR
      afrBins1   = array,  U08,      0,  [8x8],  "Volts",      0.0196,      0,    0.0,     5.0,     2
#else
; Should never get here but just incase put message on screen
  #error "No O2 sensor configuration selected; Youll need to fix the settings.ini.\n\nMegaTune terminating."
  #exit ; Terminate MT
#endif
I believe this used to be handled some how many years ago.
