I have registered copies of TS running on both Windows and Linux machines. I noticed that on both Windows & Linux there is a [UserHome]/.efianalytics folder, but on Linux there is also a [UserHome]/.efiAnalytics folder (note the case difference in the word Analytics). Since the Linux file system is case sensitive, I was wondering if there is a typo in the code that is splitting up some of the preference files on Linux only. On Linux the tsMS.reg and tsUser.properties files get put in the efiAnalytics folder and all other files go in efianalytics. In Windows all files are in the efianalytics folder.
What is the correct folder for all preference files?
Install folder differences: efianalytics vs. efiAnalytics
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
Re: Install folder differences: efianalytics vs. efiAnalytic
They should all be in the .efiAnalytics folder.
I will bet it is as you speculate that the landing pages are using lower case.
I have those two directories also.
Code: Select all
ls -ld ~/.efi*
drwxrwxrwx 6 jsm jsm 4096 Nov 28 12:44 /home/jsm/.efianalytics
drwxrwxrwx 2 jsm jsm 4096 Feb 18 2016 /home/jsm/.efiAnalytics
Yep, found it...
Code: Select all
public static File getAppCachingDir(){
File dir = new File(getUserHomeDir()+".efianalytics"+File.separator+AppProperties.appName+File.separator);
if(!dir.exists()){
dir.mkdirs();
return dir;
