no sensor cal drop down
The TunerStudio, tool tab is only providing a TPS cal selection....nothing for temp/thermistor, etc. Do you need to be connected to a live MS unit for this to be accessed and loaded.
Re: no sensor cal drop down
Almost certainly yes.
Connect your Megasquirt ECU and create a new project.
Did you try Unlock Calibrations?x-faktory wrote:The TunerStudio, tool tab is only providing a TPS cal selection....nothing for temp/thermistor, etc. Do you need to be connected to a live MS unit for this to be accessed and loaded.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
It sounds like you have an MS1 project open.x-faktory wrote:The TunerStudio, tool tab is only providing a TPS cal selection....nothing for temp/thermistor, etc. Do you need to be connected to a live MS unit for this to be accessed and loaded.
If you do indeed had an MS1, there is no option to calibrate your thermoster or AFR tables.
