V3.0.15 Undo Redo buttons
titi
Post by titi »
Hi, I think there is a bug in this version because Undo and redo buttons are not availaible..
Do you have the same problem with this version ?
LT401Vette
Re: V3.0.15 Undo Redo buttons
Post by LT401Vette »
There does seem to be an issue with undo and redo.
titi
Post by titi »
Is there a link to download an old version ?
I found beta version link, but not official old version link
Blown88GT
Post by Blown88GT »
titi wrote:Is there a link to download an old version ?
http://www.tunerstudio.com/downloads2/T ... 3.0.14.exe
titi
Post by titi »
many thanks
LT401Vette
Or move forward... Undo redo is fixed in 3.0.16
titi
Post by titi »
LT401Vette wrote:Or move forward... Undo redo is fixed in 3.0.16
:yeah!:
benckj
Post by benckj »
Just updated to 3.0.16 and now I have sync problems connecting onto MSPNP v3.57. Worked yesterday and now it connects then disconnects multiple times. What a pain as I was making progression with my tune and have time off over Xmas to play.
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
LT401Vette
Did you figure out what was causing your issue?
I'm pretty sure it is unrelated to the TS update, but would like to verify.
benckj
Post by benckj »
No havnt sorted issue yet. May be chasing a cable issue with micro USB connection.
Jim
Toyota MR2 98 3sgte
