MS Ultra logging views
On the Graph and Logging tab in TS Ultra, is it possible to change the colour of the graphs and the number of graph entries (def 4)? In MLV it was a text file edit...
Re: MS Ultra logging views
MLV has the MegaLogVIewer.properties file with the defaults, but you can change colors, number of graphs and traces per graph through the UI..
I TS, the UI menus are not there for simplicity, but you can edit the LogViewer.properties file in the TS install dir to change them.
Code: Select all
# the max number of graphs to create selectors for
numberOfGraphs=3
# Depricated, ignore..
numberOfOverlayGraphs=8
# number of traces per graph
numberOfOverlays=4
I didn't have that file in my TS install directory..created it and included the sample text above...works fine...so can start from there..
Thanks for the reply and assistance...
Here's my newly created file
numberOfGraphs=1
numberOfOverlays=10
white= -1
black=-16777216
dark_blue=-16777038
blue=-16776961
yellow=-256
dark_green=-16731648
green=-16711936
red=-65536
dark_red=-5111808
dark_gray=-10921639
gray=-8355712
lightGray=-1381668
cyan=-16711681
magenta=-65281
pink=-20561
orange=-14336
graphForeColor0=cyan
graphForeColor1=blue
graphForeColor2=yellow
graphForeColor3=magenta
graphForeColor4=white
graphForeColor5=green
graphForeColor6=red
graphForeColor7=orange
graphForeColor8=dark_red
graphForeColor9=dark_green
graphForeColor10=pink
numberOfGraphs=1
numberOfOverlays=10
white= -1
black=-16777216
dark_blue=-16777038
blue=-16776961
yellow=-256
green=-16711936
red=-65536
dark_red=-5111808
dark_gray=-10921639
gray=-8355712
lightGray=-1381668
cyan=-16711681
magenta=-65281
pink=-20561
orange=-14336
graphForeColor6=red
