TS custom.ini MS2 V3 adding a Fuel and oil Pressure Gauge
Breastfed
Post by Breastfed »
Hi
Hope this helps anyone looking to add 2 Gauges using both ADC6 & ADC7 with MSextra (MS2 V3.0)
I already had an oil pressure gauge working in TS and I needed to add a Fuel pressure gauge.
Well it took me a while to figure it out with the custom.ini but here's how I did it
1> create a new text document with the following below and save with the name "custom.ini".
2> My custom.ini file is here C:\Users\TOSHIBA\Documents\TunerStudioProjects\My VFRX750-SC RUNNING\projectCfg
[OutputChannels]
oilSensorVoltage = { adc7 * 0.0048876 }
; No use 0psi=.5v 100psi=4.5v to calculate pressure from voltage
oilPressure = { oilSensorVoltage > 0 ? (oilSensorVoltage - 0.45) / 0.04 : 0 }
fuelSensorVoltage = { adc6 * 0.0048876 }
fuelPressure = { fuelSensorVoltage > 0 ? (fuelSensorVoltage - 0.45) / 0.04 : 0 }
[Datalog]
entry = oilPressure , "Oil Pressure", int, "%d"
entry = fuelPressure , "Fuel Pressure", int, "%d"
3> Open TS and go to designer mode, configure the gauge properties, you will see Oil Pressure and Fuel Pressure added to the list of available sensors
Breastfed
old guy
Re: TS custom.ini MS2 V3 adding a Fuel and oil Pressure Gaug
Post by old guy »
A lot easier to use the " Add Custom Channel Wizard" in TS.
jsdevel
Post by jsdevel »
Where did the 0.0048876 constant come from?
