I had this error screen appear during cold start auto tune (engine running about 7 minutes), and I could not clear it. Eventually it locked up tuner studio and I had to kill it via task manager. When I looked at the task manager window, java runtime SE memory usage was the highest on the list. I updated to TS ultra last night. A couple of days ago I had a similar problem with the cold start auto tune where it locked up with no error message. This is on a win 7 laptop running the latest Java code. I verified that I did not have any old installations of java on the system. Up until this week, I have never had tuner studio crash. Weird"No Time Column found" message during VEAL, TS ultra lock up
Re: "No Time Column found" message during VEAL, TS ultra loc
Any ideas? I'm dead in the water with a new engine if I can't use auto tune.
Was this while capturing a log from the Graphing & Logging tab?
A normal data log, not an SD log?
This was during a normal datalog. from the drop down under data logging in the upper left corner of the UILT401Vette wrote:Was this while capturing a log from the Graphing & Logging tab?
