1996 Toyota Corolla ae111 blacktop 20v
MS1 v3
I have a project I have been working on and haven't touched it in over a year. About a week ago when setting it back up again i had to update TS to the new version. Apon startup I received the firmware signature mismatch. Went to update firmware but it still gives me a window that says TS doesn't have the ecu definition ini that's compatible with the firmware. Can I just go to the index of ini page and grab the mS1 ini file from there? Thx.
firmware upgrade issue (ini)
Re: firmware upgrade issue (ini)
Seems like TunerStudio is perhaps being a bit strange here and I'm not sure it really makes sense. Best to wait for the developers' input.
I went in today and opened the project properties box. Firmware is 029y4 but with I go to find the Ecu definition it gives me 029y3. I have the new firmware (029y4) and when I open the msns config setting it says the signature is 029y3. The signature seems to be correct when looking at it.
That's correct. The issue is what you posted in your first post.
It appears you are getting timeouts from the controller.
Your signature is truncated and the versionInfo 'T' command appears to be timing out.
What type of connection are you using?
If you open Mini-Term and type a T, what do you get back?
I did a port check as well as the Mini-term. Here is what I received from both. I'm using a USB to serial cable (PL- 2303 driver ver. 2.0.2.
https://vimeo.com/197975121
