I logged on tonight to report problems getting shadowdash to use a dashboard I made from within TS Ult 3.0.14
I found a thread saying to use TS 2.6 to do what I am trying to do.
Is this still true with the 3.0.16 update? Last time I loaded and opened a different version is corrupted project properties files (I think) and sent me around and around on existing projects.
Thanks,
Kyle
SPR
Will TunerStudio MS ultra edit shadow dash dashes?
Re: Will TunerStudio MS ultra edit shadow dash dashes?
Yes, the trouble isn't with TS, the trouble is that Shadow Dash needs to be brought up to speed.
The new release of SD is getting there and will be out soon.
Ok, thanks Phil.
I will try that on a different machine. Last time I opened a current project with an older version of TS something happened to the ECM and I had to rebuild the project essentially. I didn't think to use a new project to just build a dashboard.\
Thanks,
Kyle
Thanks,
Kyle
This is good to know as I was having multiple problems with SD and had hoped 3.0.16 fixed some of my issues. Things got worse with intermittent connection issues including interference with MS during run time. You should post out a note to others on issue and projected time frame to rectify.LT401Vette wrote:Yes, the trouble isn't with TS, the trouble is that Shadow Dash needs to be brought up to speed.
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Hey Phil,
Following up on the Shadow dash dashboard editing from within Tuner studio.
Is the update features in SD you spoke of, out? If not, wasn't it TS 2.6 to regress to to edit dashboards? Thought that was in this thread but don't see it.
I have to make another working RC tablet dash.
Thanks for the info!!
Kyle
Sector Purple Racing
Kyle
Yes, Shadow Dash 1.5 is out and that supports TS 3.0 dashboards.
