v3.0.17 small problem
Postby Huey » Sat Jan 21, 2017 7:11 am
If I go into closed-loop idle settings the close button on the bottom right doesn't work, it only makes the text disappear in the box at the bottom. I have to click the x at the top right to get out.
Dodge 2.2L MPI Turbo Power Running MSnS1/Extra.
Chevrolet 5.3 LM7 running MSnS2 /Extra
Chevrolet Twin Cam 4 cyl running MSnS2 / Extra
Home of the USB data logger---> http://www.msextra.com/forums/viewtopic.php?f=67&t=34901
Huey
Re: v3.0.17 small problem
Postby LT401Vette » Sun Jan 22, 2017 9:48 am
It sounds like perhaps some type of exception is occurring?
It seems to work fine for me.
Can you send a TunerStudioAppDebug.txt?
Postby Huey » Sun Jan 22, 2017 1:09 pm
Here you go...
Debug file attached
(182.89 KiB) Downloaded 18 times
Huey
Postby LT401Vette » Mon Jan 23, 2017 9:03 am
Hmm, don't see any exceptions.
I switched to your firmware, still seems to work.
Perhaps I need to load your msq?
Is this online and offline?
Is it only the Closed Loop Idle settings dialog?
Postby Huey » Fri Jan 27, 2017 5:14 pm
I was online making changes. Here is my MSQ.
CurrentTune - Copy.msq
(122.64 KiB) Downloaded 8 times
Huey
Postby LT401Vette » Fri Jan 27, 2017 6:41 pm
I'm still not having any luck reproducing...
Does it happen every time?
What field has focus? (I think I have tried them all)
Return to Tuner Studio
