v3.0.17 small problem
If I go into closed-loop idle settings the close button on the bottom right doesn't work, it only makes the text disappear in the box at the bottom. I have to click the x at the top right to get out.
Dodge 2.2L MPI Turbo Power Running MSnS1/Extra.
Chevrolet 5.3 LM7 running MSnS2 /Extra
Chevrolet Twin Cam 4 cyl running MSnS2 / Extra
Home of the USB data logger---> http://www.msextra.com/forums/viewtopic ... 67&t=34901
Re: v3.0.17 small problem
It sounds like perhaps some type of exception is occurring?
It seems to work fine for me.
Can you send a TunerStudioAppDebug.txt?
Here you go...
Hmm, don't see any exceptions.
I switched to your firmware, still seems to work.
Perhaps I need to load your msq?
Is this online and offline?
Is it only the Closed Loop Idle settings dialog?
I was online making changes. Here is my MSQ.
I'm still not having any luck reproducing...
Does it happen every time?
What field has focus? (I think I have tried them all)
