After starting up TS, with the normal Gauge cluster-tab showing, there's no "Gauge Cluster"-menu-item listed in the File-menu.
Only when switching views to a different tab, and then back again to the Gauge cluster-tab, the menu-item "Gauge Cluster" is then listed in the menu.
I know the File-menu is updated, depending on which tab is viewed at the moment.
The first time TS is opened, it should really show the Gauge Cluster menu-item in the File-menu, because that's the tab everyone starts out on.
Is repeatable on PC & Mac versions.
Menu bug in TS?
Menu bug in TS?
Re: Menu bug in TS?
Good to know... On OS X the menu's don't like updating on the fly for some reason.
