changing gauge scale in tuner dash
my oil gauge reads x1000 how can i change it to x100
Re: changing gauge scale in tuner dash
Need some more info. Is the actual value off by a factor of 10, or is the gauge just scaled by a factor of 10 so the oil gauge is only using a small portion of it? If the former, change this in generic sensor input (assuming this is an oil pressure sensor that's configured that way). If the latter, right click on the gauge cluster and check Designer Mode. Then right click on the gauge and hover over Dashboard Designer and click Properties Dialog. There will be settings on there of the min and max of the gauge.
thanks that did it
