reversed pwm idle setting,
E30stroker
Post by E30stroker »
if i switch the setting to reversed , does it affect the test mode options,
in test mode 0 is open 100 is closed, and it test out mechanically that way also: 75 percnt is 3/4 closed more air flow than 100%
if i toggle settings reversed/normal, in idle control. it does not affect what direction the valve opperate in test mode, is what ive noticed,
running the motor at idle , pwm idle duty % , guage on -tuner studio dash ,- reads 100%, and may reach 93%,
but it just stays in one state, does not oscillate even though the engine is running way to rich and stalling out, and oscillating on its own
possibly due to afr correction,
the other settings in ts would also never closse the valve, so im wondering what it STAYS at 100% during low,rich idle and not adjust at all to correct?
m20stroker.msq
pre boost ,87 327i stroker, 885 head and b25 intake,, cometic .140' head head gasket , IG1000's, MS3 PRO, long tube headers, mild porting, race cam, welded diff puck clutch, poly all around, subframes reainforced, 2.93 rear diff, dtm shifter, aem wideband, e46 front controll arms, slr mini kit,
slow_hemi6
Re: reversed pwm idle setting,
Post by slow_hemi6 »
Test mode kind of lives outside the normal operating code. So unless there is a reverse in test mode screen I strongly doubt anything in the normal operating settings could effect test mode.
E30stroker
okthats good to know, here is my msq
im going to take a data log pretty soon here to log its settings,
ran it this morning and most of the setting were similar, and the valve gauge showed 100% and doesnt move,
Curnt m20 stkr msq.msq
E30stroker
2017-03-11_16.16.15.msl
2017-03-11_16.15.08.msl
slow_hemi6
The ford valve I have been using has an operational range. Too little DC it does not regulate and too much DC it does not regulate. Have you tried to run yours in warmup mode? That is how I confirmed the operation and figured out the operational range of my valve using the idle warmup duty table with the engine running.
E30stroker
so if my valve operate in reverce my warmup curve should be in reverse am i correct?
nathaninwa
Post by nathaninwa »
That's correct. What valve are you running?
E30stroker
itd a t wire vdo came off the motronic 027 computer, i just tried what you told me basically the motor will shut off with with a ristiction over 50 %
and still hunts at idle when i open it all the way at like 2 percent
E30stroker
two* wire
