This ms1 ver 2.2 build is fully working, running via older laptop which I borrowed. I havent squirted anything in years and trying to get back into the game with this new Hyundai build but I had to buy a newer laptop
i got a debug attatched but if the .msq is needed then I can upload later tonight from older laptop since this one wont even read it. lol
I downloaded hypertherm
port check
com4 opened
115200 baud
No connection made.
9600 baud
"ms1/extra format 029y3 **********"
1 valid port found.
new latop Win 10 switch to Win 7, still no communication
95 Probe v6-t MS1
00 Accent 2.0L-T,Ms1
14 Factory Five 818 MS2 4 ebc/meth only
03 Tiburon v6 SC 1st ever MS
93 Tracer KLDE,Compounds w/2 of everything, Twin Megasquirt ?
00 Lotus Esprit v8-TT Full MS3x/ls1 coils/water/Meth
97 200sx 1.6L Stock, MS2/3.0, Sequential, CBR1000r coils
Re: new latop Win 10 switch to Win 7, still no communication
What type of USB to DB9 Cable do you have?
If you open the port in TS's Mini-Term and type a Q
Do you get a response?
I have a DB9 to USB cable and a pin to pin DB9 cable.
If you have an old computer with DB9 serial ports, use them.
My DB9 to USB worked with Windows 10 at first. One week later stopped working without a reason I can understand Then I started using an old laptop with Windows XP, and the DB9 to USB, the cable worked again (but not with the win 10 lap, checked it).
Yesterday DB9 to USB stopped working with my old win XP laptop. Won't work anymore. Used a DB9 to DB9, at least works for now.
Problem solved!!!
I'm using the typical db9 to usb offered by DIY,
I went offline to start a new project and manually selected the comm port and .s19 file after loading updated firmware and it Detected!!!!
95 Probe v6-t MS1
