I apologize if this has been brought up before and solved, but a quick google search didn't resolve the issue, so I figured I'd make a post.
I just completed the installation of my MS3x and LS2 truck coil conversion in my 1997 v6 mustang. It's a stock motor that i'm using to learn how to tune with before I swap in a v8. After fiddling with the VR pots I finally got the motor to catch. However, the engine rpm still "hunts" big time during all of the phases and if I don't give it steady throttle it will die. I tried adding more fuel during these phases but my afrs stay at a constant 19.0 the entire time until right before the motor stalls. I attached a log file and my tune that will hopefully describe what is going on better than I can. And for what its worth I am using APSX V2 wideband sensors.
Thanks,
Austin
AFRs constant 19.0 during cranking, warmup, etc
Re: AFRs constant 19.0 during cranking, warmup, etc
Just realized this should have been posted in the Tuning section. Mods please remove.
